It’s a bit squeezy. I had to route the power for the drive cages under the motherboard. I’ve got some more work to do with the cable management and the installation of the SSD pool.
There’s a good amount of cooling in this case. The rack is in an unconditioned room so I’ll see if this is enough. Most of the heat being generated in the case is from the HBA’s and the 10Gb NIC.
