Anniversary 2.0 Build check
Hey guys, I posted a bit ago with some questions about the NK 4 build and since then I’ve joined the Patreon and done a ton of research.
I’m very close to ordering parts for my build here and just want a sanity check that my parts are compatible.
My goals for the build are to replace my current server/NAS which I’ve bumped up against some compute and memory limits. I use it mainly for storage and Emby streaming, but I also use about 6-10 Docker containers and I want to be able to add a couple VMs as well. So I’ll be moving my current storage to the new build and adding a couple SSDs for cache and VM storage.
I’m open to suggestions on tweaks to this. I went back and forth between the X9DRD-7LN4F-JBOD and the X9DRi-LN4F+ The DRi works for me because I was pretty sure I wanted to go with dual 2667s V1, so that makes the board cheap enough, and between that and the savings on the coolers I can buy an HBA and still make out ahead. Any flaws in my logic? Thanks again for this awesome community and resources!
Mobo - X9DRI-LN4F+ Price - $169.99
CPUs - 2x [E5-2667 ] Price: $80
https://www.ebay.com/itm/SR0KP-INTEL-XEON-PROCESSOR-E5-2667-2-90GHZ-15M-6-CORES-130W-C2-PROCESSOR/264502212356
Coolers - Arctic [Freezer 12] Price: $48
https://amzn.to/2pvPN4S
RAM - Samsung Price - $17 M393B2K70CM0-CF8Q5
https://amzn.to/317dqOO
PSU - TBD - will be on the hunt on /r/buildapcsales this November Currently looking at 650-750W options that come with 2 CPU cables
Storage - will be migrating 6 HDDs from my current build and picking up 2 SSDs to add a cache drive and storage for a VM or 2
Chassis - Already picked up the Rosewill 15 bay for $100
Fans/cables/etc
Arctic 80mm 5 pack - $20
https://amzn.to/2vXRIiZ
LSI HBA HBA SAS9211-8i - $25
https://www.ebay.com/itm/LSI-6Gb-s-SAS-PCIe2-x8-Host-Bus-Adapter-HBA-SAS9211-8i/293285186186?hash=item444928ca8a:g:nukAAOSw9oVdqgz5
2x SFF-8087 to SATA breakout cable - $16
https://amzn.to/2wdb82x
I don’t think the Mobo - X9DRI-LN4F+ will fit into the Rosewill. I suggest double checking the motherboard form factor, this one’s too big!
Ack! Now I’m glad I checked. I guess I missed the extra E in EEATX. I guess that leaves me with the x9drl-if or one of the narrow ILM ones (Maybe the X9DRH-7F?) It doesn’t need to be silent, as it will be in a utility room, but that room does share a wall with my living room, so I don’t exactly want it screaming.
Update: I ended up going with the X9DRL-if
I used the OBO option and the seller accepted $180
